I have a 94' Rinker Captiva 180 with original trailer. I bought it from a friend last summer and moved away. While moving it to our new home, one of the tires lost it's tread and by the time I barely made it to the house before it was completely flat. The current tires are Nankang Load Max Radial 175 80 R13. To be honest the tires always seemed stressed to me as at operating PSI, they were pretty loaded down even with a dry and unloaded boat. I'd like to be making 300 mile roundtrips with it this summer so I'd like to see if I'd be better moving to a bigger tire.
I looked up the dry weight of my boat and it comes in at around 2500lbs with the 3.0 Merc. What concerns me is that this tire and others that I'm seeing appear to be a load range C with a weight capacity of around 1360 per tire or 2720lbs total. The boat weight will most likely hit that with gear loaded for the boating trips and be over that with the trailer weight.
Does anyone have thoughts or opinions on where to go from here on tire sizes?
Thanks
Curtis
Thanks
Curtis
