Re: trailer tongue jack, saltwater use, longevity
I have to replace my jack at the end of EVERY season because the internals get corroded and the gears strip out. I had been using the cheap Harbor Freight $20 ones, but "upgraded" to a $40 one from West Marine last season. The claim on the box was something to the effect of "good for 300 hours of saltwater use", but, alas, it has now siezed up also. Any thoughts for a replacement?
...not trying to insult ya' Chuck but I think ya' got what ya' paid for !!!!!
Check-out the ads right here at
iBoats .....they're on sale with a TWO YEAR WARRANTY.
As a part of my clean-up routine, I even wash down the jack. Several times a year I'll pop the top cap on my jack and brush some grease around the gears and lubricate the crank handle and swing arm pivot. Shucks, I even smear a little grease on the extended shaft and lubricate the axle !!! I've NEVER had to replace a jack due to corrosion.
You might try a slightly higher rated jack to reduce internal wear.
FWIW....Ed in 'ol Virginny
