I have looked at the other trailer wiring posts and didn't find the same problem I am having. This might get a little long, please bear with me:<br /><br />My tow vehicle is a 98 Toyota 4-Runner with separate turn signal and break lights. I had the correct splitter installed professionally. The plug is the flat, 4-wire type - white, brown, green, & yellow.<br /><br />I have tested the vehicle side with a tester and all seems to be in correct working order. <br /><br />I bought a new wire set for my trailer. It has the flat connector but it has 5 wires - white, brown & green, green, brown & yellow, and yellow.<br /><br />Using a new brake light/turn signal with 3 wires - white, black, & red, I can get only the running lights to work when hooked up correctly or the turn signal light will burn constantly but brighter. <br /><br />I am positive I have a good ground all around. <br /><br />Basically what I get is running lights only - no brake lights or turn signals. It is also this way with the old wiring.<br /><br />I greatly appreciate any and all responses to this problem!!<br /><br />Thanks in advance...<br /><br />Russell
