Trailering a boat
foresteronw
I have a 1989 Sunbird Eurosport. It is a 21 foot cuddy cabin, low profile, sport boat. The boat weighs apporx. 2900 pounds. I have a tandem axle trailer with surge brakes. I will be moving from North Carolina to Massachusetts next year and I am wondering if it is ok to attempt to tow this boat that far with a 2002 s-10 pick-up. THis is the vehicle I use to two the boat with here, and it is rated to tow this much weight, but now I am talking 750 miles. Any tips??????????
Seaboo2
Re: Trailering a boat
If it's rated to tow that much weight it should be fine. <br /><br />Tips... <br />If you don't have one, get a trailer spare tire.<br />Check + service the wheel bearings on the trailer.<br />Check the trailer tires (make sure they aren't dry rotten).
butch290
I hope you have a V6 and a trans, oil cooler,you have some big hills to climb.keep your speed down, go for it.
JB
"It is rated to tow that much weight."<br /><br />How much weight? How much does the boat, engine, fuel, gear and trailer really weigh?<br /><br />You are pretty fuzzy there, Foresteronw. If you boat weighs "approximately" 2900 lb, your gross towed weight probably exceeds 5,000.<br /><br />Is you S-10 really rated to tow over 5,000lb.?<br /><br />If it really is, be sure your surge brakes are in A-1 shape and have the truck drive train, trans cooler and cooling system checked thoroughly.<br /><br />Also, all of the above advice is very good.<br /><br />Good luck. :)
foresteronw
Thanks a lot guys. I think I am going to have the boat and trailer weighed just to be sure that it will be safe. There actually aren't too many hills on the route I will be taking, I make the trip several times a year. The truck does have a transmision cooler and it is a V6, 4.3. I will be changing all my wheel bearings and four tires before I go, they could most likely use it anyway. And I will defanataly bring a spare tire, thanks for the info.
RICKRICK1
Ensign
You might add an extra set of wheel bearings,a hub, and grease. They can come in pretty handy in the middle of nowhere. Also a good roll around jack, beats crawling around under the trailer if you need to change a tire.
MrBill
Many boaters neglect their trailors. I run through a fairly extensive routine each spring for my annual 200 mile trip from permanent residence to lakehouse, and a boat-off-the-trailer check for the return trip in October. My fall check with boat off trailer, involves lubing rollers and swivel points, including replacement of worn or cracked rollers.<br /><br />You don't mention age of trailer or amount of use so for your trip lift trailer (yes, 1" with the boat on it is Ok) and check tires, bearings, etc. for wear and irregularities. Grease bearings, properly inflate tires and inspect brakes. Then don't forget wiring, lighting, coupler, safety chains, and the hitch equipment....proper size ball shank?? Finally, check and re-check straps and harnesses that hold the boat to the trailer, including winch strap and winch safety chain (don't leave home without one).<br /><br />I use a Ford F150 Supercrew for a 4800 lb load with plenty of capacity, but an S-10 seems a little on the light side for 5000#. Weather conditions play an important role, I'm rarely concerned with pulling capacity, the critical spec is stopping capablity under all conditions. On a long highway trip, overheating and engine/transmission strain are rarley issues, except under extreme conditions. Up here in New England, I can't recall ever seeing a vehicle pulling a boat on the side of the road with those problems. As others mentioned above......get a spare tire. <br /> <br />Have a safe trip........
C17LoadSmasher
When similar topics have been posted, I've also seen suggestions like shrink wrapping your boat to aid in keeping road sludge off of your boat. You can get it done at boat yards/marinas usually. It might also help in fuel economy, because an S-10 is sure to suck the gas with a boat behind it, I am sure. My '00 Silverado sucks gas with 3000# on the back of it (hmm well it is a V8... :rolleyes: ). Don't tow with a cover on unless you know for sure it's good for driving (many are not), the wind will tear it up, and nothing creates more drag than a flapping cover in the breeze, not to mention it can flail the finish on fiberglass as well. Hope this helps.<br /><br />--Chris
B_Eager
I would check the trailer-boat weight again myself. I estimate you at closer to 4,000 pounds unless they started making fiberglass lighter. New England has new trailer brake requirements that you may want to check before crossing the borders. If you are coming through I95 or I84 check construction in CT before you leave they have been doing work on both this past year
mattttt25
all good info posted above. also recommend turning off the overdrive unless you're on completely flat run. quick story- each year we run from n.j. to canada with trailered boats. one year my uncle has a flat and the whole caravan has to stop and wait for him to find one in the local area because he didn't have a spare. the next year he has the spare (and is proud of it). half way there, the spare flies out of his boat, my dad hits it and we're on the side of the road changing the van tire. lessons sometimes come the hard way...
