I recently boaght a 2002 Wellcraft 2600 Martinique and decided to buy a Venture trailer from the dealer to tow it and have it shipped to my house. I thought my 2010 AWD Sierra Denali (1500) would be able to handle towing the boat but I think I might be wrong. Here's the specs:
2010 Denali has a towing rating of 9400#
Venture Trailer is a bunk tandem with 7400# rating - wait of the trailer is 1300# GVW8750
2002 Martinique 2600 has a dry weight of 6500#
-84gal fuel=~500#
-26gal water=~217#
-gear I will estimate at 500#
obvouisly I'm getting close to the trailer max so I will make sure not to have any water in the water tank, try to keep the fuel under a half tank when trailering and keep some of the gear off the boat until after launch (the boat will be slipped most of the time anyway)
My problem is that I have severe sag if I put the trailer on my truck. (I wouldn't even attempt to move it) I'm not sure what the tongue weight is (I know it should be around 700#) but I'm not sure if they set up the trailer correctly at the dealership for my boat. Bunks are even with the transom but I have read that you may need to move the axles to properly set the tongue weight.
can I get a weight distribution hitch? I have read that a reese SC will work with surge brakes but I don't know if it will work with an aluminum I-beam trailer.
Am I screwed? not in the budget to go buy a 1 ton truck....
-D
-84gal fuel=~500#
-26gal water=~217#
-D
