Re: Trailering
2011 Durango ?Up to 7,400 lb towing capacity [1] with 5.7L HEMI ? V8
Crownline 225 LPX Dry Weight 3800 lbs.
58 Gal. fuel 58x6.2 ? 360 lbs.
gear 600 lbs.
trailer 800 lbs.
very ruff total 5560 lbs.
As bifflefan posted. go to the scales. and check with the dealer. You could have a lower rated hitch. Check your window sticker if you still have it.
A good rule of thumb is 80% of max. 80% of 7400= 5920 so your looking good all the way around if it all checks out. Lots of other numbers to check out GVW, GCVW. These and more are on your spec. plate in the door frame.
Four big fishermen and all the gear for a weekend at the cabin and you could be way over for the Durango.
So keep reading and learn all the limits.
Put a tool box together for the trailer and another one for the boat. You'll need them.
Crownline is one of my favorite boat makers and the Durango should handle it.
