Transducer Check
north40
Is there any way to test to see if transducer is working other than connecting to different depthfinder? I have a Lowrance X28 and when I turn it on, it reads 5-600 feet even when only in 20-30 feet of water. :confused:
north40
Re: Transducer Check
Transducer is thru hull design. Unit is in Auto Mode. Just purchased boat used last summer so I don't know if unit worked before or not. All functions seem to work other than it gives bezerk readings.
Boatist
You can put your hand under it or your foot and you should be able to feel it pluse. Since it is a thru hull is it shimmed right to be pointing straight down or is it pointing off to one side.<br /><br />I would start by going thru the manual and setting to factory defaults. Then move out to 30 or 50 feet of water. If it is drawing a bottom on your LCD then you are close. I turn up until upper 1/3 part of screen starts to black out.
Richard Petersen
Time to call Lowrance. They give free trouble shooting advice and part# for the repair.
north40
Thanks for your help. I will check suggestions as soon as I can get wet. If no luck I will take RP's advice. This is a OEM installation on 99 Stratos and it may have reached it's expiration date.
