Re: Transducer Go Bad?
Usually when it freezes, it has lost the transducer reading and is showing last read. Are you at full speed when it freezes? Check your ground wire and see if the 'ducer is firmly epoxied in the bilge. With what you can get a similar unit for today, I honestly would replace it. For less than $130, you can get the entry level "5" series from Hummingbird.
