I have a 22 foot single sraight inboard and am trying to determine the best location for the transducer. There is not much room on the transome because of the trim tabs. The only spot would be pretty much behind the rudder and prop. If I shoot through the hull should it be forward of the shaft or along side of it and how far to the side of the shaft. Would directly above the shaft forward of the prop cause problems or would the shaft just be part of the surface clutter.
