sightsrv
- Joined
- Nov 9, 2012
- 82
Have looked at other posts about this and just cant seem to get a gripe on the subject. Do own common sense but its went right out the window..Am sorry seems am repeating something also..A transom mounted transducer..Do you still cut-drill holes in your boat? Why dont know having a real hard time with this..I see holes cut inside, outside of your boat. I see once cut out inside there may be foam...etc..could cause a problem..Seen one installed cutting out the bottom on the outside of the boat..looks like his method got in the way of side bars on his trailer and ripped it out.
Am sure its here some where. Is there in very simple english a post about this mess? Just what is realy involved in a transducer mounted on a transom? Is this one of the like humminbird fish finders with a antena on the mount you screw into the boat? Have no clue why I cant figure this out..Could be ebay and youtube..I just dont know..Hope someone can fix my brain and add some common sense..This subject have none at all. All electronics on boat are 1997..Trying to update all of them..Tearing her up to do so is a nightmare..Looks also to be hiring a pro is something no way could afford.Add a link to her. Ifs major surgury dont think could cut her up..Spelling is bad not concered with it. Maybe best leave her be. Have a hard time putting her under a blade.
:grumpy::facepalm:
See in pictures..At wheel is the 97 tracker wide eye c..#5040163..At troll is a humminbird 200dx..#5802057..Both oem from 1997..I thought could buy upgraded for both that can just plug in to existing mounts and wiring..As with everything best can see is 4get that..Thats what has lead me to this post. Cant plug-n-play..Have to cut up your boat..Is my thinking screwed?
:grumpy::facepalm:
