transducer mounting: is inside the hull mounting a bad idea?
3car
I have a 15' dixie fiberglass boat, and i want to install a humminbird fishfinder. I was gonna mount the transducer in the bottom of the hull near the bilge pump with some epoxy, but a couple of my buddys said I'll regret it because the fiberglass will make iit loose too much signal.
What are your experiences? I hate breaking transducers off, and It seems to happen on a regular basis!
PondTunes
Re: transducer mounting: is inside the hull mounting a bad idea?
If you're breaking them off go with the glue in, it seems like the only thing you might lose is a little depth.. Meaning if you get into really deep water the signal won't reach the bottom.
If you're breaking them off you're probably running pretty shallow ;)
Also, if your hull is cored you'll need to remove enough foam to get down to the fiberglass.
jtexas
You can test it by putting enough water in the bilge to submerge the transducer and using sandbags or something to hold it steady for your tests.
If your fishfinder has water temp, it won't work with the 'ducer inside the boat.
Main reason for a 'ducer to get broke is because its mounted incorrectly - the bracket will enable it to swing up out of the way when it hits an obstruction, if its not screwed in too tight.
I broke mine couple years ago - fixed it with marine-tex.
Texasmark
Not a problem if you do your homework.
Easy way to test is to put it in a bag of water.....learned that on here....I used to do as j said; put some water in the bottom of the boat, but the bag idea has merit. You can use some duct tape to tie things in place till you get your readings. Tape the bag up around the cable to seal it.
For reference, in calm water, put the ducer over the side and take a reading in as deep water as you can find. If there is structure, like trees or something besides the bottom, so much the better.
Then put it in the boat where you want to mount it and compare readings. Moving it about may help also. If you have a gain control, reducing it till a target is just visable will really tell you the difference when you move it inside and have to crank up the gain to see the target. If you normally boat in shallow water (50' or less) I'd say that gain isn't all that important.
If gain is really obstructed, like if you do have a double hull, moving around might locate an area where there is just one hull thickness. Course material is important....if solid alum or glass not a problem. If a cork or air core, gotta make other arrangements as pond tunes mentioned.
Important thing is to use a good epoxy and get the bubbles out between the ducer and the hull. Air is not a good conductor of sound waves. Also lightly sand both surfaces and degrease them prior to installation.
I know the other supplier of sounders has a web site and they recommend an epoxy, but I've mounted several and was not picky about epoxy....just careful to mix it slowly so as to not introduce air into the mix.
HTH
Mark
3car
thanks for the replies. My hull is single thickness where the transducer will go next to the bilge pump, so i'm gonna test it out.
