Transducer mounting Question?
Setzer
We installed a Humminbird Xplore 9 a few months ago, and when we did the install we just mounted the transducer in the same spot the old one was. At the time we weren’t really thinking about side imaging.
The issue now is the right side imaging is getting blocked by the lower part of the hull, which you can see in the pictures. The hull sticks out just enough to shadow that whole right side.
What I’m trying to figure out is whether it would be OK — and what the advantages or disadvantages would be — to mount the transducer in front of the motor, down the centerline of the boat. In the pictures I circled the spot we’re considering. There’s over an inch of clearance between the motor (trimmed all the way down) and where the transducer would sit, even with the motor turned.
I know I’ll probably lose accurate high‑speed depth readings, but that’s not a big deal for us. We care more about the down and side imaging, and we fish the same areas all the time so we pretty much know the depths already.
I don’t want to mount the transducer on the back next to the trim plates. In shallow water the back end of the boat sometimes drags or bumps the bottom when coming out of the hole, and I’m worried about snapping the transducer off.
So the main question is: Is it OK to mount the transducer between the motor and the hull on the centerline, knowing I have about an inch of clearance with the motor trimmed all the way down?
I did contact Humminbird, but they mainly tried to sell me a thru‑hull transducer. I don’t have access to the inner hull and I’m not interested in drilling or cutting holes in the bottom of the boat, so that wasn’t helpful.
Any input from folks that know about this or who’ve mounted theirs in a similar spot would be appreciated.
PS. ignore the dropped axle we where putting new leaf springs on.
dingbat
I have both thru hull (conventional CHRIP) and side scan transducers on my boat.
The thru hull is mounted on center line, 18” in front of the transom. Works like a charm at any speed, but get interference with the boat in reverse.
Installed the side scan transducer 10” off center to clear the prop wash.
Setzer
That's great for you, but I don't see how this answers my question?
dingbat
Did I not answer your question?
You will get interference anytime you have the prop in reverse. If that’s ok with you, you’re good to go.
Jeff J
He doesn’t have a through the hull transducer nor does he wish to install one. His question was about mounting a transducer between the hull and the motor. So, no, you certainly did not answer his question.
Setzer
yes that is correct I do not and do not want to install a through hull trans. I don't want to put holes in the bottom of my boat. As far as having interference while in reverse I don't care I just want both sides of my side scans to work.
Jeff J
I have never seen a transducer mounted in front of the motor as proposed. I don’t see a problem with doing it unless the lower unit can interfere with getting an accurate depth but it could be trimmed to be out of the way if needed when idling around.
Setzer
With the motor down and trimmed all the way down and back I will have over an inch of clearance. Most people are telling me not to as it will disrupt the water going to the prop and MAY make the motor slip or cavitate. But I don't think this will happen as the trans. is sitting high in the water the then prop and even on plane the trans. will still be higher, I will just loose high speed readings and I am ok with that. This is my thinking am I wrong?
Jeff J
Sorry, I didn’t catch how shallow that rig is setup to run or that the transducer would pretty much be in line with the prop hub. My thinking above was along the lines of a motor mounted at a more traditional height. That is one heck of an anti-cav plate on the motor but I don’t know if it can compensate for the transducer.
Setzer
The boat is a flats boat we can run in about 6in of water there is a jack plate that I can raise the moto up 6in. That's also why the cav plate is so big. I finally talk to someone at humminbird and they said no matter where I put it on the are in front of the motor it will block the beam and mess with the water going to the prop. So my only real option is a through hull witch is a 100% no or a flush bottom mount and try not to tear it off. I can get a flush mount kit from around 125 bucks. Anyways thanks for you help I just need to decide to leave it as and deal with it or rick the bottom mount.
FLATHEAD
Looks like you could move that a few more inches toward port side and down a little and the sonar would clear picking up the hull. If you could somehow rig it temporarily to see. Maybe mounted to a long enough piece of wood you can lower down and see how far you’d have to move it. Then mount it accordingly. Just a thought
Setzer
That's what I was starting to think about moving it down a few inches and over some like you said. Do you think that would mess with the water flow to the prop to much?
