I installed a Lowrance 510C on my "02" Starcraft 190 LE. When I put the transducer on the back of the boat I mounted it on a 3" X 5" peice of nylon type board glued to the transom. The bottom of the boat has a 15 degree upward slope from the center to the outside. When I mounted the transducer I have it setting level or 0 Deg. to the bottom of the boat, with the inside of the transducer line even with the bottom edge of the boat and the outside edge of the transducer maybe 3/4 to a inch below the the bottom of the boat to where it looks level. Just wondering if this would be the right way to set it up. I tried to go as to what the manual said but sometimes a person reads it the wrong way. Thanks for any input.
