You can use your cell ( might need a app to get that feature ) to measure your dead rise , I would guess your in the 12* - 15:* range . Bigger older boats usually never got close to the somewhat standard 19 * Doesn't Airmar only offer 2 models for different dead rises ?What degree transducer do I need for a 81 Silverton 37 Convertible? I am using a shoot thru hull tran
Asking for dead rise degrees , not frequency for his MFD .What transducer does your electronics need? Use that one
That is what an angle finder or digital level will tell you as deadrise changes from bow to sternAsking for dead rise degrees , not frequency for his MFD .
Multiple models but only two deadrises, 12 and 20 degreesDoesn't Airmar only offer 2 models for different dead rises ?
Then 12* is what he needs , no way did they make that dead rise close to 20* more like 10* the more I think about it .Multiple models but only two deadrises, 12 and 20 degrees
Found mention of 14 degrees in early model but by 1989 the brochure specs transom deadrise at 17 degreesThen 12* is what he needs , no way did they make that dead rise close to 20* more like 10* the more I think about it .
