transem problem?????
ratdogs
I an a new boat owner and I noticed that the transem flexes when the boat is under full power. I have about a 1/2 inch gap between the transem and the rest of the boat. The gap is from about 3 inches from the top on the side down to the motor mount. I have a 1977 Starcraft Super Sport 18 footer with a Johnson 140 O/B. Does this indicate that my transem is bad or is this normal? If bad, can anyone give me suggestions to fix the situation. I do not want to go diving for my motor.
JB
Re: transem problem?????
Can you flex the transom manually when the boat is on the trailer?
ratdogs
the transom does move some when on the trailer. I have some rot on one side. After cleanning off the old caulk I found that the gunwail and transom has a 3/4 inch gap. Any suggestions?
JB
Yup. New transom. :(
robpoe
JB is, of course, correct. Time for a new transom. Probably time to cut out some of the floor and look @ the stringers, too .. they might be rotting out too...<br /><br />It's a big job, but a rewarding one (from what I've heard). If you decide to do it (or have it done) then you're looking at many more years with that hull. <br /><br />Or, there's always the option I went with, which is finding a new hull to hang that 140 Johnson on...But if you do decide to go that route, make sure to have the transom / floor / stuff checked in the newer hull - you definately don't want to purchase a hull with a rotten transom .. as you'd be right back where you started..
MercMark
Technical Knowledge factor not very hard if you do your research and you're comfortable with powertools and carpentry.<br /><br />Labour Factor - not worse than digging post holes for a fence.<br /><br />Annoyance factor - fibreglass itch, sticky messy materials, =high annoyance factor.<br /><br />Money - maybe more expensive than a junker hull to replace<br /><br />Satisfaction Factor - moderate to high midway through... I'll tell you more when I'm done.
