- Joined
- Mar 8, 2009
- 43,603
2008 Ram 2500 and the service 4WD light comes on every now and then for the past week or so. Been busy so didn't get to it until today. Thinking it may be a bad connection, removed the connector and all good. Read up on the issue and most lead back to the transfer case motor.
So I'm putting the truck up and it acts like its in 4WD Low and sure enough it is and won't come out. Put it in its space and shut it on/off a couple times trying to clear, but that just made it worst. Now its in between Low and High and if I try to put iin park the gears grind. It also will not go FWD or REV, so shut it off and going to order a new transfer motor.
Good times, sure wish I had the old shift lever now. Cant complain a lot because its at 155K without many issues
