lester
- Joined
- Sep 23, 2008
- 92
So anyways guys I have been sibbing for awhile now and loving it. I even went ahead and got a trailer so I can spend more time boating and less setting up every time out of the back of my minivan(got to be a real PITA). When I started out boating I knew I always wanted a Rib, but simply couldn't afford one, so I made due with my Sib. I ended up finding a deal on craigslist a month ago on a fantastic 2001 Zodiac Yachtline 340rl(yes I understand that this is not top shelf compared to real hypalon Rib, but I am taking small steps up in my boat ownership) and went ahead and bought it. I have been using it with a tiller and love it. I was looking at the layout and thinking I wanted to put a bench seat in the back, get a very small center console and hook up a motor to controls so it will essentially be the deluxe model. I have found a boat junkyard nearby that has a seat and console for dirt cheap (needs some cleaning), but still looking for a motor. I know just about any motor near the 25 range already set up for controls is going to be a longshaft and the boat requires a short, so I will have to do a transom elevator. Here are the questions:
1. Do you think I will have any problems with attaching the controls to the transom(ie-steering..etc)? If I decide to do this project I will have no problem drilling holes. I believe the entire transom is about 15" tall by 30" wide and is fiberglass(or plastic composite).
2. If hooking up the controls should work, what is the best transom elevator to use considering I will be having a remote motor? It seems like the only options in this category are the elevators(essentially raise the transom directly above it) or the jacks (mount to the back of the transom and have an offset and elevation that the motor mounts upon)? I am leaning towards the elevators due to having controls.
3. I know having this setup will definately eat up just about all extra space in the boat, but I really only use it with 3 people max and mainly just 2. Do you foresee any problems with attempting this layout?
I will admit I do not have very much knowledge with boat modification, but I have been around workshops long enough to know how to handle a tool and with the help of other Iboats members feel like I can definitely accomplish this task if possible. Thanks
I attached pictures of the boat. The total length of the boat is 11'2" and the interior space is 7'7" by approx 32"
ps-so my pictures are too big and I cant get to load right now, but will shrink them and repost later tonight. Thanks guys.
