Re: Transmission cooler required???
My Ford Explorer Sport is at a shop getting a cooler today!
I did allot of research on this subject, posting here and on a Ford forum. I just purchased this truck with 63000 miles. I belive all explorer/rangers have a small cooler built in, however since researching the subject, the extra cooler is the way to go. Heat burns up transmissions, coolers are the safe bet.
I found that a very good unit is a brand called "Long". These coolers are well built and have a bypass built in where the fluid does not enter this cooler until it hits a certain temp, therefor when its cold outside your not "overcooling" the fluid.
Also, if you lease or are concerned with warranty, they may not cover your trans if your towing without some type of cooler...this was the case with my Honda minivan. You basically could void your warranty without thier tow package.
The cooler I am getting installed is the max that will fit and the cooler/installation is about 200.00. I located a small trans shop where I could speak to the owner and get good advice. The Ford dealer was clueless in this case.
Lastly, all the recommendations on the Ford Explorer/Ranger were to stay out of OD, no exceptions. I guess the Ford tranny is not up to it. In a final note, on my Ford I was told to look for one with a 3.73 or 4.10 rear, I found one with the 4.10, so I guess time will tell if all this advice works or not.
Hope this helps.
Mike
