kkatarn327
- Joined
- Sep 11, 2016
- 2
Hello all,
Being in my third month of boat ownership, I have already found this forum to be incredibly helpful and wanted to become part of the community. I hope that with experience I will be able to contribute beyond merely asking questions like the one I have for you folks today.
A few months ago, my father-in-law gave me his boat (a 16' Sanpon Catapon manufactured in Fresno, CA circa mid-1970s, if anyone is interested and/or has heard of these boats) which has a 1974 Mercury 200 20HP motor. I have operated this boat and motor several times each summer for the last few years so I am not unfamiliar with it. However, now that it's parked in my driveway, we've been putting it to very good use this season. When I got the boat, the only issue was that the water pump impeller on the motor was deteriorated and thus not circulating water. We replaced it at the beginning of summer and it has run fine (nearly every weekend) until last week.
We were up at Lake Edison here in the Sierras (I'm never taking a boat on that road ever again!) when the prop ate a mudbank hard enough to kill the engine. After this episode, the motor had the telltale symptoms of what I later learned to be a spun propeller, and I took it out of the water immediately. After bringing it home and spending a week drenching the prop nut and shaft with penetrating oil, I was finally able to remove the prop and saw that indeed the rubber hub had sheared completely off the shaft insert and was more or less in a pulverized state. Being that the prop was about as old as the motor and a two-blade, I ordered a new Black Max prop to replace it which should be here in about a week.
Now even with the prop and shredded hub removed, I am still experiencing some abnormal behavior which I'm hoping is not, but likely is, an issue with the transmission. I will do my best to describe as follows.
Turning the prop shaft by hand:
-F: turns clockwise normally (with "click" every half turn or so), doesn't turn counterclockwise.
-N: turns freely in either direction (also normal)
-R: shaft locks in both directions, doesn't turn at all (abnormal)
Pulling the starter cord just slowly enough to rotate the flywheel and driveshaft:
-F: turns clockwise (normal)
-N: turns counterclockwise (not normal)
-R: turns counterclockwise (normal)
Additionally, shifting to reverse is difficult and requires some "wiggling" of the prop shaft and/or starter cord, which was not the case prior to the incident (I also confirmed that there is no obstruction to the shift cams in the power head). When we replaced the impeller a few months ago, we (involuntarily) gained much experience attaching and removing the lower unit, and I can confirm that at that time, this behavior was not present.
My question (finally, I know) is, based on these observations, are there any issues with the transmission or crankcase? If so, how can I best approach them? If I do need to remove the lower unit to address the issue(s), I'd like to do it prior to installing the new prop and changing the gear oil.
Any and all advice is welcome. Please let me know if any additional information would be helpful. Thank you!
