Transom alterations
Flashman666
I am new to this forum, and have been greatly impressed with the wealth of information that is available here.
I have a question to do with the proper height of the cavitation/AV plate to the keel. I?ve read a number of threads on this topic and have gleaned much helpful information.
I have a 30 year old 14? Sears Gamefisher open aluminum boat with a 15? (measured) transom. I recently purchased a more or less new 15 hp Yamaha short shaft to go on the back. However, on my first sea trial, it porpoised badly and water literally gushed up the back of the transom when I opened her up. On closer inspection, I could see that the cavitation plate was a full 3? below the keel (this seems to be because the distance from the cavitation plate to the clamps is 15?, but a full 18? to the top of the motor mount ? thus, putting the motor flush on the transom puts the cavitation plate far too low in the water).
When I raised the motor up close to an inch and trimmed her out fully, things improved. The gushing of water over the transom stopped, but the boat continued to porpoise (albeit not as badly, but I still had to have my passenger sit on the rear bench seat as we ran).
I?m thinking what I need to do is replace and refurbish the transom and raise it up a full 3? (this way, the motor would sit flush on the top and the cavitation plate would be at the same height as the keel). I?d reinforce it on both the inside and outside of the transom.
So, does anybody have any reason to say this is not a good idea? Tips? Many thanks in advance.
Chris1956
Re: Transom alterations
It is likely a good idea, however, the extension needs to be strong enough to accept the motor's power. If the extension breaks off, the motor could be lost.
Design it carefully.
Coastalguy
Look at the engine owners manual to see how far below the boats bottom
the anti cav plate can be set. Most engines in this size range call for even
with the boats bottom down to 1 inch below Some however like my 25hp
Johnson say even to 2 inches below. I raised mine 1 mounting hole on the
engine using the original holes drilled in the transom which resulted in the
engine sitting about 3/4 inch above the transom ( with a little block ) and the
cav plate is now just a bit more than 1 inch below the bottom. Result less
spray coming off the engine, performance about the same.
