Re: Transom and stringer replacement!
Could someone please give me an answer on this. I have under taken replacing all the wood in my bass boat. the question I have should I coat all my wood with the epoxy risen before I fiberglass them in , meaning the floor both top and bottom and the stringers and transom!
It depends on what you mean.
all wood should have a coat of whatever resin you are using applied to and then let it harden before doing any glass work on it.
most of the time its much easier to put them in place before doing it though.
If you mean using just a coat of resin and no glass on some portions of the wood, then no, it needs glass for it to hold up long term.
Read some of the other threads on the same subject and you'll get a better idea of what to do.
