How does one check to see if the transom is in good shape? After reading a few threads related to this topic, I don't want to find out my transom was bad when my engine drops off the back of the boat and takes part of the boat with it.
I have 1969 Starcraft Sportabout with a 1979 70hp Johnson. The transom has a piece of wood mounted to the aluminum exterior of the boat. Not a very good desciption. I'm sure most of you know the design. I have crawled into the back of the boat and tightened the bolts that are fastened to the transom supports.Quite a few loose ones. Since finding those loose bolts I will be checking that part of the boat often.
