Re: Transom condition - update on inspection
I had a Boat inspector look at my transom crazing/cracks (see previous pics). He had a piece of equipment that measures moisture. He did a full inspection and found that YES my transom has been compromised. The fiberglass to the plywood has been compromised due to the transom showing a level of moisture. This is why I am getting the crazing/cracks. The transom was moist from about the water level down and completely dry above that. The report is that my transom is not rotted and is just fine for the age of the boat. The only other moisture that was found was on top of the cuddy where my moon roof is, from the moon roof to the front (top section only), although not really bad, it is expected with the age of the boat. I did reseal all the railing, window and cleats just to stop any further water penetration.
I did end up etching every small and large, long and short crazing and cracks on my transom with a dremel. I then cleaned with acetone then Marine-tex every etching done, a bit of sanding with 200 grit, cleaning with acetone and 2 coats of Gel coat and a final 600 grit light sanding. I did find a spot down by my drain plug that was showing fiberglass, I marine-tex?d that and a spot in front of the boat. Looked pretty good after all that work.
Although I have done all this work the inspector did not think it necessary and that the crazing/cracks will most likely come back due to the transom being compromised. He thought to just take pictures of the crazing/cracks and look at them again in a month to see if they are getting any worse. But, I did all the work and I guess I will see if I get crazing and cracks, will report back in a month or so.
