transom drain plug
jlsmith
Where can i get a transom drain plug for a 98 bass tracker pro team 175. I think it is a 3/4 threded plug. The threads are like pipe threads not the bigger threads on some of the plugs i have gotten any help would be appreciated.
itspaidfor
Re: transom drain plug
Are you sure it has threads ? most are just the rubber plug you insert then fold the handle over to make it tight.
Socal Pat
Yah, sounds like you're looking at the livewell inlet and not the transom plug hole.
This is the exact same boat I have, I have looked for a plug myself and I ended up getting a pipe plug not sure of the size can look and let you know later I do not live near a BPS so I went to a couple boating stores and they didn't have the plastic type that would fit it
Stealthbobber06
