Transom drain plug
Steve079
My 14ft Klamth does not have a drain plug, without a garage or carport, having to rely on a cover still allows some water inside. I want install a drain, and a garboard plug was recommended. A 1" hole, and then 3 smaller holes to secure the plug to the transom. I drilled the 1" hole, but am now having second thoughts. I/m worried that I won't be able to seal up the 3 smaller holes enough to prevent water entry. Any suggestions for a better solution?
GA_Boater
Thousands of boats use the garboard drain you describe. Use lots of marine sealant like 3M 5200 or 4200 and it won't leak.
Grub54891
The absolute best way is to drill oversized, fill with epoxy mixed with cabosil. Then drill to the correct size and install the plug, with sealant. This insures water will not contact the wood in the transom. If its simply a aluminum boat, just use sealer.
JASinIL2006
I did just that. I used liberal amounts of JB Weld to bed the flange of the garboard, and then used stainless machine screws and nuts in the three holes. That was about 5-6 years ago and it still looks and works great.
Its a tinny, and based on the pics of the Klamath utility boats, etc on their web site, they show a plug
maybe they started adding them later.
however no problem adding a drain. just seal it with some 3M 5200 or 4200 or 4000UV and your good
Steve079
Hey, thank you all. I have to admit, drilling a hole in my '74 Klamath DLX, that didn't leak at all, kind of freaked me out. Well, not kind of. A lot.
get over it, drill it, seal it, go boating
Steve079
"get over it, drill it, seal it, go boating"
Got it, over it. Thanks again.
No problem..... it took me a week of perseverating prior to drilling all the rigging holes in my boat after restoring the hull.
