Re: transom extension?
Actually, it's probably a good idea. (Done right, that is.) It's the perfect excuse to rebuild the transom. I raised the transom on my 18' Reinell during the rebuild of the whole boat. Basically:
1. Leave the outer skin, gut the transom interior and the interior fiberglass skin.
2. Get your wood ready, i.e.: epoxied together and cut to fit....sealed with epoxy.
3. Install wood to inside of outer skin with clamps. Wood will be sticking up about to the height you want.
4. If you wish, install a couple kneee braces with 2 layers of 3/4" plywood bonded together with the epoxy and sealed.
5. Now glass everything in. On the outside of your transom where the new wood shows the correct height, grind a taper into the old skin about 4 to 6 inches down. Start laying fiberglass to even it out. Once you get it smooth and level, ....this took the most time foir me......I then laid 2 layers of fiberglass completely across the transom and about 8 inches up the sides of the hull and down below. (You'll grind some of the old stuff there as well, to make room for the new stuff.) It came out perfect. I used to get water from wakes occasionally splashing in the splashwell...that doesn't happen anymore.
Be forewarned.....thgis is a lot like fixing that small area of the bathroom floor that has some rot.....and you end up having to gut the whole bathroom once you find there is a lot of rot. When you get to the stringers, you may find they are far gone.....and the project gets bigger. Much bigger.
