Transom getting replaced have ???
eagle787
1987 Blue Fin S170 Aluminum
we're going to be replacing rotting transom, questions I have are:
Drilling holes in new wood transom, should I drill oversize so that the epoxy can coat the inside of hole?
if yes how much over size should I drill?
Should new wood be drilled while in the boat, back drilling through holes in aluminum skin, or should I place transom in boat , mark where holes go then pull it out and drill holes on saw horse ect..
Any and all advise is greatly appreciated.
eagle787
rookie456
I have the same bluefin s170, but mine is a 1986. I replaced my transom 2 years ago. I am no expert, that was the first transom I replaced. I can answer your questions with the way I replaced mine and how it worked for me.
I glued the 2 pieces of plywood together and cut the left and right sides to fit, leave top long so that you are able to pull the wood out of the boat after checking fit. Put transom in boat and drill holes. I used a wood block as a drill guide to make sure I was perpendicular to transom. Remove transom. Drill holes again 1/4” larger and fill those holes with peanut butter epoxy. When you drill the holes later 1/4” smaller it should leave you with an 1/8” of epoxy. I have a video on YouTube explaining steps I took while replacing mine. Message me if you would like the link to the video.
eagle787
Please send me the link to your video , also what excatly is peanut butter epoxy? Thick thick ..mix it yourself or do ya buy it
Thanks
PC on the Bayou
If you're talking about drive / motor installation holes through the new wood, then here is what I did.
I marked the hole locations once the basic transom was shaped and ready to install. Then I took the new wood out and drilled oversized holes (I think 1"). I then filled these holes with thickened resin (taped off the bottom and poured them full then let them harden. Once I installed the new wood, I drilled the 1/2" holes through from the outside of the transom using a drill jig to hold the drill square to the transom.
Doing the above let my new holes drill (for the most part) down through the middle of the resin filled holes making the holes completely sealed with resin.
You can look at my thread to see what I'm talking about ( Click Here ).
jbcurt00
As long as you're not monetized, you can post the video IN a post using the upload feature, rather then a redirect link to the video
jbcurt00
Try to avoid circumventing the forum and trading info via email and/or private messages.
The whole point of an open public forum is to share info amongst all members, present & future. Discussions via phone, text, email and private messages arent open and available to everyone, only the 2 members in the discussion which defeats the purpose of a forum you used to start the private discussion.
And just a suggestion, but never post personal info publicly on an open forum, emails & ph#s could be used by trolls, spybots, malware and hackers, why help them out....
Thanks
This PSA was brought to you by the Iboats forum.
rookie456
I tried to upload the video directly to the post, it is telling me the upload file is too big. Here is the YouTube link, I am not monetized, hopefully this is acceptable, and works.
Chris51280
Ensign
drill holes with everything installed or it will never line up. Some drill oversize and fill with resin and then drill again. I drilled a bit bigger and then used a thin brush and coated the holes with resin to seal. the bottom holes are the more critical ones since they will get all the water splash in the bilge and water dripping from top. so seal where you can to keep the wood dry
Emerger
This is a video of someone replacing the transom in an aluminum boat.
eagle787
great advice thanks ,
JohnnyMat
I have a question about a similar boat ('87 Starcraft SS-160) My transom has never been drilled for an outboard before. The P.O. only had a 35hp with tightening bolts. I am adding an '83 70HP Johnson to it. Anyone have any tips on the best way to drill for new holes in this case. I don't think I have to pull a perfectly good transom out just to drill/epoxy it....correct?
jbcurt00
Start a topic about your Starcraft, asking questions about yours here, is considered a hijack and discouraged
