Hi All, I found a pretty solid little 14' vintage runabout to use with my vintage short shaft Merc Mk58A. This is a very simple boat which has no raised floor and no splash well and appears to be a pretty early fg boat. It seems very solid so maybe that's before they began to scrimp on materials ?? The 1 1/2" transom is solid with no evidence of water. Since there's no splash well, and the top of the transom was sealed it's all still dry. I'm puzzled however that the transom measures 17" instead of 16". It's been running for 45+ years, so I guess it's okay, but I thought it was ideal to have the transom at 16" so that the bottom cavitation plate would ride just at or below the hull to catch relatively undisturbed water?? If I use it as-is, the bottom cavitation plate on my motor will be a bit over 1" above the bottom of the hull. Since this boat has had a motor bouncing on that transom for over 40 years, there are a few stress cracks at the top of some of the transom laminates, so I want to beef up the transom a bit anyway which means cutting the cap to add resin/cloth, etc, and if I'm gonna do that anyway, I'm thinking I should cut the center portion of the transom down to the correct height so that when I add the new layers of fg cloth and resin, that it comes out to be right at 16". All opinions and help appreciated.<br />Many thanks,<br /> Marty
