I have a 21ft carolina skiff seachaser deep v with a 20 inch shaft 150hp motor.My cavitation plate is about one inch higher than the bottom of the transom(lowest possible position).Problem is the bottom of the transom is not the bottom of the boat.It has a stepped bottom.I other words another section thats v shaped(looking from rear)that has all the drain plugs aerator pickup,etc.The prop seems to be even with this part of the boat.Ive seen other boats and the cavitation plate seem to be lower.My questions are did my dealer screw me?I suspected this when I bought it and the dealer told me it would be able to run in shallower water.Ive heard of an extension kit to convert to a long shaft,where can I find one?The boat is two years old.I think it should ride dryer when I go offshore.Does shaft length affect how "high" the boat sits on plane?When I raise try to raise the bow in choppy seas I get a "rooster tail."Hope I was clear enough in explaining this.Any help appreciated.<br />Thanks<br />P.S.I saw on spec sheet somewhere that said this boat has a 25inch transom if this helps
