tashasdaddy said:you will get better perfomance if you raise the engine, with a jack plate, too, much drag from the lower unit so deep. this bolts to the transom, and the motor bolts to it. mount it so the flat part above the propeller is about 1 1/2 inch above the bottom of the hull. should give you great performance.
Do you feel like the performance will be bad without the jate plate?
http://www.iboats.com/T_H_Marine_Hi...55660691--list_time.1175009067--view_id.40130
