Transom Height
walleye one
My buddy just bought a ss 201 that was an I/O in its previous life. He basically bought an aluminum hull; he would like to convert it to an outboard, cutting down the transom bracing it and building a splash pan. Can anyone tell me what the transom height should be?
Bob Gilvary
Re: Transom Height
20" would be a starting point.
The I/O conversions to outboards I've seen have just closed up the outdrive hole and added a gill bracket to hold the outboard.
walleye one
Re: Transom Height
Thanks for the info, he did consider a bracket but he has access to any materials he would need and can weld aluminum so he would only have his time invested. Thanks again for the reply.
HopeSheFloats
Re: Transom Height
... Can anyone tell me what the transom height should be?
Depends on what the motor used requires...ie: long shaft or short shaft...one is usually 20" the other 25" and I don't have enough experience to know if there are other 'standards'.
Bob Gilvary
Re: Transom Height
In outboard measurements a short shaft is 15", long is 20" and X-long is 25". Most of the offshore boats use the 25".
Pugetsound
Re: Transom Height
If your buddy has the material and does his own welding I would highly reccomend a stern bracket. Saves the interior space for humane use. And the boat would probably run very well on a stern bracket. IMHO I had one on a 19 ft GlasPly and it was outstanding.
barato
Re: Transom Height
or even INhumane use....that's a good place to club fish, cuz it's easy to wash down later :D
