Transom height
speckhunter
I have a 16' alumacraft that I resently had to put a used motor on and have found that the motor is about 6" longer than the one that came with the boat. The new motor runs very well and I like the extra power it has compaired to the old one.
I have two questions. 1st can The new motor be safely raised on the transom? 2nd what would be the best and least expensive way to raise it?
I went from a 25 hp to a 30 hp.
steelespike
Re: Transom hight.
Re: Transom hight.
To keep it very basic a couple of aluminum angle irons and about 1 1/2 inches of plywood
attached to the transom. If you did it right you could also make it like a jack plate so
you could fine tune the height. You could search here and on the net for key words like do it yourself jack plate how to raise the transom
speckhunter
Re: Transom hight.
Re: Transom hight.
Thanks for the ideas guys! I think I can make that happen. Fair seas!
speckhunter
Re: Transom hight.
Re: Transom hight.
I used the Idea in the link you sugjested and modifyed it a little. thanks again
jigngrub
Re: Transom hight.
Re: Transom hight.
Take some pics, wed like to see your handywork!
