transom hole question
w1bcr
hi all
is the alpha one cutout the same ?
bolt right on ?
jim
Same as what...?
we need more information to be able to answer you
w1bcr
sorry i had added that to a thread going already
i have a 1965 1A-1B- 1C EZ Shift i would
like to swap out for a 1988 3.0 alpha one that is in a junk boat
Ayuh,..... That thread was 6 years old,.....
90 days is the time limit for postin' in the archives here at iboats,......
Please read, 'n follow our postin' rules, 'n guidelines, a link to which is in my signature,.....
Ayuh,..... I doubt the hole is exactly the same, but I believe you'll only need to drill different holes, 'n grind out the keyhole abit in places,....
I'm pretty sure, you won't have to fill in what's there, 'n start over,.....
But I've never worked on a A-B-C drive either,.....
w1bcr
ok thanks for the help good to know
i had found a 1965 runabout in great shape with a junk motor
and at the same time on cs a junk boat with a good motor and outdrive
but someone got it before me
angin thanks
