beerrun
- Joined
- Apr 1, 2007
- 134
Hi, so it looks like tomorrow night we are finally ready to put the transom in the little 14' Valiant.We sandwiched 2 pieces of 3/4" AC plywood together with fiberglass, dry fit it, rigged all kinds of stuff to get any bow out of the hull/transom joint and its pretty tight.Being a total newbie I have asked for lots of advice. I've gotten so many different opinions from so many different people on the best method for attaching it to the hull and I have kinda narrowed it down to 2 options. Please tell me what you think.
OPTION 1: I was told to use this stuff called Cabosil. My local Marina sold me West systems #406, colloidal silica, they said its the same stuff. The plan is to mix this with my resin(non blushing epoxy) to the consistancy of peanut butter.Spread it with a notched trowel using enough to fill any voids(if there are any they're very small), join the transom to the hull & clamp the snot out of it.
OPTION 2: Use fiberglass mat and epoxy resin in between the transom and the hull being pretty generous with the resin and then put them together and clamp the snot out of it.
Is one method better than the other? Any other suggestions? How cold is too cold to do this? Its getting chilly at night here.Thanks as always for any input.
