hi all,<br />I have just completed making the new transom for by boat. <br />I have some epoxy from Clark Craft coming in the mail, along with a thickener(starts with a c), and some finely chopped fiberglass. I was told to mix it all together until it is like peanut butter, spread it across the transom, and stick it in. <br />but...<br />I am replacing the transom from the inside, so I have removed the top of the hull with a sawzall from above the transom. I have to squeeze the new wood between the outer hull and into the groove that is in the inside of the boat where the stringers meet the transom and also a portion where the battery trays are raised up and will be flush with the transom when finished. its hard to picture that isn't it?<br /><br />well, its a very very tight fit for the wood, on the test fit I had to beat the new wood in with a hammer. I am afraid that when I put the peanut butter on and beat it in place that it will all just be scraped off. so what do I do?<br /><br />also, do I need to glass the inside of the transom at all? it is not a sandwiched transom except where the battery trays and stringers attach. <br />thanks for all the help I have recieved, I would't have gotten this far if it wasn't for all of you.
