rocketboy52
- Joined
- Mar 21, 2006
- 26
I posted a few weeks ago on this forum about how to find a transom leak. I pulled the engine and found that the Y pipe was wasted.
After pulling the Y pipe I saw alot of oxide on the inner transom plate. There was some serious build up on the plate and one of the lower bolts was missing. I decided to pull the transom plate, and was really glad that I did because it ended up being broken in two. You really couldn't tell it was busted when then it was bolted in place.
The two lower bolts where totally wasted too
From the way these bolts rottend, It looks like these bolts are aluminum, but I haven't been able to find a replacement source for these. Can I replace these with stainless Carriage bolts from the hardware store, or is there transom special about these?
Also, I have seen a number Pre Alpha transom plates on Ebay, but my Steering tube attaches above the tiller arm cut out, All the plates I have found have the steering tube mounted below the tiller cut out. Is there any reason why I need to find a transom plate idendical to my orginal? Here is one I am talking about.
http://tinyurl.com/otakm
Lastly, while I have the engine out, I am going to replace the bellows, the main trim lines, the transom gasket, and paint everything. Is there anything else I should make sure I do while I have the motor out?
Thanks, in Advance for all your help! d
