Re: Transom long or short shaft
JN626.... A 16" transom, measured vertically at the transom center, would be considered designed for a 15" short shaft engine. Your 20" shaft engine will work on that boat but be aware that you will have quite a bit of engine dragging in the water. Also, at high speeds, this drag will create what is usually refered to as a "Rooster Tail" (water shooting up and back from both sides of the engine). In short, there's nothing to keep the engine from operating on that boat, buit it will be impossible for it to operate properly.
