transom modification
whfmznb
First of all, thanks to all who participate in this wonderful site.<br /><br />I have a SeaNymph 14R aluminum boat. I a also have a transom mount trolling motor. I always had my 4hp outboard and the trolling motor side by side on the transom. I now have a 15hp 4 stroke outboard and don't have room for both on the level portion of the transom. I want to build up one side of the transom to hold the trolling motor. I can cut a piece of PT lumber to follow the contour. If I drill holes and screw this on, is there sufficient material in the transom to hold it? i.e. wood inside the transom?<br /><br />Thanks again...
Solittle
Re: transom modification
Don't know your boat but would do exactly what you plan except I would use stainless bolts through the transom.
whfmznb
I'm picturing the modification setting on top of the transom and attached by placing large screws straight down into the transom. Or is a "ü-strap" over the block and bolted thru the transom going to hold better? Or both? It's 34lb thrust trolling motor.
