transom mounting bolts...
benlh77
'84 Mercruiser 5.7 898 on a 19'Chris Craft...<br />Hey guys, I'm trying to tighten the transom bolts (I think thats what there called) because I can see the gap between the transom and the plate that surrounds the gimbal housing that is supposed to sit flush with the transom. It's loose and when I fill the bilge up from the inside, water pours out but when I push from the back of the housing, it stops. My question is, "what is the easiest way to tighten these bolts?" They have to be tightened from the inside and I see no way of getting to them. Special tool? I can get a wrench on there barely with my pinky but no way to torque it.
Re: transom mounting bolts...
Well,...........<br /><br />After you pull the Drive,+ then the Engine,+ the Transom Assembley to Replace your Rotten Transom........... :( <br /><br />Once you've got everything going back together,....<br />The Transom Assembley is the 1st Piece to be Reinstalled,......<br />The Transom Assembley Studs,+ Nuts are Tightened Then,..... Before the Engine Reinstall.................<br /><br />That Boat Ain't going No Where....... She's Junk at this Point............... :rolleyes:
