Transom Mounting Holes for Tilt and Trim Engine
jslu
Engine = 1989 35 HP Merc SN# 120583
Boat = 1990 Starcraft Select 150
When I originally purchased this boat two years ago, it had a 1990 60 HP Merc with 3 ram tilt and trim. At the point of purchase I knew the 60 Hp was trashed with broken center piston. As a replacement I opted for a 1987 35 Hp merc witout tilt and trim. Different mounting hole patterns, so, I had some old holes in the transom to fill and new holes to drill. Worked great, no problems.
Recently I purchased a 1989 35 Hp Merc (described above) with the the 3 ram tilt and trim (which I really like) and I plan on replacing the current 1987 Merc 35 HP (non tilt and trim) now mounted to the boat.
Obscure question is this:
As a heads up for me, will the transom mounting holes for the 1989 35 HP Merc line up with the now plugged holes left from the 1990 60 HP Merc?
Anybody out there know this?
Thanks,
John
