Re: Transom Plate Assesment
OK, I know I'm going to get beat-up, slammed and hammered on this one (be kind...) but the transom shield on my 72 MC-1 looks worse than that one and the bellows fit OK.
15 or so years ago the PO of my boat took it in to have the drive rebuild, Ujoints let go too, and it thrashed the rim that the Ujoint bellows mount to. The lip was almost all gone. The shop (which is pretty reputable around here, not saying it was the right call) advised my buddy they could replace the transom shield for $$$$$, or just knock the rest of the lip off and mount the bellows further back. $$$$$ wasn't in his budget so they knocked that lip off and mounted the bellows to what was left. There was plenty of unobstructed outer bore to mount the bellows.
I never had a problem with the bellows leaking at that connection and have replaced them a couple times since then, never having the bellows leak at the transom shield connection. (I once had the bellows split after 6 year, but that was owner neglect.....) I'm not saying this is the proper way to do the repair, but it has worked OK on my MC-1 drive. The only thing that's off is the bellows stretch a bit further (maybe 3/4"?) than they are supposed to, but they have never leaked from the transom shield connection. I always make sure to use a liberal amount of bellows adhesive since this is not the intended location for the bellows to mount, but it has worked fine.
Before even thinking of doing this, make sure the mounting surface for the bellows will allow the bellows to fit further back, after the lip is knocked off. I'm pretty sure the newer transom shields won't allow this as there are "bellows stops" (for lack of a better term) cast into the housing, that would interfere with the bellows sliding further back.
I tried to find a pic of my beat-up transom shield, in my plethora of pics, but couldn't find one.
OK, let'er fly.......
