oops!
- Joined
- Oct 18, 2007
- 12,932
the boat is at the mechanics getting the drive hole cut out.
i just talked to the mechanic who has been all day measuring for the hole.
he says because i dont know what motor is going in....a v8 (350 base ) poss a 383) or a v6 (4.3).....an alpha or a volvo....that he doesn't know where to cut the hole.......
1. he says that there is a difference in hole hight between the 4.3 v6 and the 350......he says the hole is different due to the different motors.....
i thought the 4.3 was a 350 with a giant saw taken to 2 cyls?....so....same block !
he says that the same alpha drive has to be at different heights, due to the motor size......that means if i cut the hole for the 4.3.....and mount the alpha 1 on the back.....that i would never be able to go to the 350....because the anti cav plate would be in the wrong spot. ????
2. he also says....that the volvo hole is different than the merc hole...(different sizes)........
3.....it sounds to me like horse feathers.......espec about the difference between the 4.3 and 350 hole size.....its the same durn drive....!
what is the truth guys ?
thanks
oops
thanks
oops
