It's been some time since I've had a chance to work on my Jon but when I tried to install the new transom core yesterday, it wouldn't fit. The old core looked to be two layers of 3/4 ply merely tacked together with staples and not sealed. I made a new core using two layers of 3/4" exterior ply bonded together with PL and coated with medium 635 epoxy resin from U.S. Composites. The core is sandwiched between aluminum structure. I had a new piece of aluminum welded onto the exterior side of the transom (old one was badly corroded) and I'm thinking that there may be some distortion. I've tried beveling the edges of the new core but that didn't seem to help much. The new core seems to be too thick to allow the inner aluminum structure to fit-up properly causing the rivet holes on the sides to misalign, so much so that I can't even get a cleco in them. So, it looks like I need to fab another transom core. Would there be any problem with using two layers of ply of differing thickness? I was thinking one layer of 3/4" and the other layer being 1/2". I don't much care for the idea but I'm at a loss at what else I can do to reinstall the core.
