I found the plywood in my '68 14' Fleetform's transom rotten. This boat has a "dovetail" stern, where the plywood stretches across the entire stern, leaving open pockets in the corners, and is glassed to the floor and on each side, and of course to the 1/4" of glass that is the actual transom between the two "dovetails". I cut around the inside of the transom to free the plywood from the sides and floor and chiseled it away from the 1/4" glass transom. I cut a new transom from 3/4" plywood, but the plywood is painted, front and back. I noticed the resin did not stick to this paint very well, so I sanded and scored with tiny holes as much as I could so the resin can soak into the wood. If I do this all around the plywood and sand/rough the paint really good will it hold up? I'm mounting an Evinrude Lark VII 40hp to this boat.<br /><br />Thanks
