Re: transom problem?????picture
capt Ultra, you said it looked like the kind of cracks from not using a transom saver. If you trim up a v6 ob the center of gravity is shifted forward. There will be little pressure on the outside bottom of the mount. The pressure will be more of a sheer, straight down on the transom. The transom saver started out on bass boats years ago when they were putting these v6's on 17' boats and little transoms. I think its a marketing ploy myself to sell a product. i have never used one on any of the boats I have had since a 1965 thunderbird that I still have with no transom problems. If the transom is soild and right, there will be no problems from towing without a transom saver. How many 24' twin engine fishing boats you ever seen with a transom saver?? I have never seen one yet and I have seen a bunch in my day. Now I will bet the problem with this transom is from water intrusion from the seem across the top or the bolt/ screw holes not being seal up. Thats where 99% of the transom problems come from that I have seen. Once water get in and softens up the wood then the cracking will begin. When you take a 2500 to 4000 lb boat and jam the throttle and put 2000 lbs of thrust on a 25" lever, that my friend is 100 times more pressure on the transom then vibration from bumps in the road. When trailering I just trim my engine up and let it ride. Have doen this with every boat with hydrolics since 1978. Never a problem with power trim either. Most engine mfg dont recomend this. I am not saying not to use a transom saver, use one if you want but most importantly you have to have a good transom to start with and have to make sure it never gets water in it. Now we need to find out how the core samples came out.
