Re: Transom Question
This is just my opinion and take it as such.<br />I have owned many fiberglass boats and most had water soaked wood transoms or stringers or both.<br />That's why some boat manufacturers have done away with using wood and others have taken steps to make sure the wood is sealed. But one little screw hole below the water line and there goes the seal. Having said that, I never did anything to repair the wood on my boats. <br />But back to your problem.<br />First, just because the wood and water coming out is brown, does not mean it's rotten, or at least the whole transom is rotten. For wood to rot, it requires oxygen. Wet wood that is sealed, can remain stable for a long time. It will be heavier but the structual strength will remain close to dry wood. <br />If your transom is not flexing and shows no sign of degradation on the outside, I would not worry about it. <br />If I were you, I'd drill a small hole at that bottom of the transom and see if any water comes out. If it does, let it drain. If you're not using the boat over the winter, I'd let it drain all that time. When you get ready to fill the hole, I'd counter sink the hole and install a SS wood screw with some 3M polysufide sealer. The same with the transducer holes. I would also check all other fittings and bolts to make sure they are well sealed.<br />My present boat has some stringers that are wet. I'm not sure about the transom. The boat is a 1978 and is still going strong.<br />Just my thoughts and suggestions. Good luck.
