I have read a bunch of threads and cannot find the info I am looking for. This is my first boat restore...by accident! Thought carpet was all i needed..ha. Ok, the transom is out and I am working on the new one using treated plywood and I think I understand that it needs resin and fiberglass to join the 2 pieces. It also needs resin on the side inside the boat and then will be glassed to the interior of the boat. If I have read or assumed anythign worn please correct me. My main question is when I set the new transom in does it just rest against the outer fiberglassed wall or how do you attach it with resin. Also, do i need to run a skim layer of that peanut butter product below the transom like the stringers?
Thanks,
Dave
Thanks,
Dave
