Transom Rebuild
phipps
I picked up a 50HP Evinrude for my pontoon tonight. While I have the motor off I am going to rebuild the transom.
Wonder if someone could give me some tips on how to rebuild it.
Thanks,
Gary
MH Hawker
Re: Transom Rebuild
When I did mine I took the old one off and it was 2 layers of 3/4 marine plywood, So I cut two pieces some what bigger than needed and used 3 M 5200 fast set to glue them together and let it sit with several clamps on for 3 days then used the old one for a templet. Be very careful to keep it square, or it will throw the motor off center.
phipps
Re: Transom Rebuild
I have my old transom off and getting ready to start the new one, but what kind of plywood should I get?
My local Lowes/HD have birch, oak and pine. I'm guessing probably oak or birch but is one better than the other?
Also suggestions on what glue to use.
Thanks,
Gary
Silvertip
Re: Transom Rebuild
None of them unless you plan to fiberglass them. You want MARINE plywood which you will likely have to special order at the big box stores.
phipps
Re: Transom Rebuild
Thank you.
Should I be using a special glue when I glue the layers together? Thought I'd read of someone using Gorilla glue.
phipps
Re: Transom Rebuild
I've been looking for marine playwood and I have a question.
I've read that you should not use treated plywood as it reacts with the aluminum. I found a website carrying "Marinedeck" plywood and it has been "CCA treated". They state CCA treating does not interact with aluminum. Is this correct? Is CCA treated wood okay?
phipps
Re: Transom Rebuild
Well, marine plywood is out of the question around here! No one has it in stick and doesn't want to special order in one sheet. I checked online and shipping is astronomical!!
I ended up getting a sheet of 3/4" araucoply. It is 7 ply and glued together using waterproof glue.
I read in another thread that several coats of exterior paint should seal it up so that's what I'm going to do.
Thanks for the replies!
junkman41
Re: Transom Rebuild
you can buy it online and have it shipped to you, I would never use anything but the marine plywood.
phipps
Re: Transom Rebuild
Looked into that, one place required a minimum of 4 sheets and a second I checked would have sent me 1 sheet for $177 shipping!
If this transom doesn't last I have enough left to build a new one.
junkman41
Re: Transom Rebuild
could any marine dealers in the area get it for you
MH Hawker
Re: Transom Rebuild
Drag out the phone book and start looking, I am sure their specialty stores, like a cabinet maker or others or real lumber yards
Rancherlee
Re: Transom Rebuild
Araucoply is good stuff, 7 ply and the same exterior grade glue as marine ply has, VERY few voids in the ply.
BatDaddy1887
Re: Transom Rebuild
When my marina guy replaced my transom, he did not account for engine height where the steering rod is concerned. He had to take the motor off and move the new transom down some. Make sure that your engine height on the new transom is in line with the steering rod.
phipps
Re: Transom Rebuild
Thanks for the tip! Never thought to check that.
Both engines have a hollow tilt tube and the rod runs through that so I think I should be ok.
BatDaddy1887
Re: Transom Rebuild
Yes, the rod runs through the hollow tube(s), but where the steering cable exits the boat frame may have very little play as mine did. Keep an eye on that aspect and you should be good to go!
cbercaw
Re: Transom Rebuild
Plywood Shmywood...Consider using a tropical hardwood such as Mahogany, Teak or Ipe...Very economical and you don't have all the waste left over from buying sheet goods. Properly Finish all sides with a Spar (marine) Varnish and it will hold up better than plywood. Not to mention it will look great for years...Guaranteed Good Luck...And YES: Use 3m 5200 behind and around all fastener penetrations.
phipps
Re: Transom Rebuild
I got the transom rebuilt and the new motor hung. Quick question, how many bolts do you have on your motor? I've currently got 4 - 1/2" bolts. Do I need more?
MrMikeTN
Re: Transom Rebuild
I redid a transom and mount. Added some extra Channel Aluminum across the back half where the transom bolts to them.
used multi layers of OAK plywood and used a waterproofing sealant, Green Interstate signs (no I didnt steal it) fiberglass cloth and fiberglass resin and gel coat.
dry fitted it then slathered it all together and put some bolts with washers thru it, cranked em down real good with a breaker bar and used a few Bessey clamps and my bench vise and let it all dry for 5 days locked up in a small shed that the temp got well above 100deg every day, Un clamped it, took the bolts out, sanded the blobs and oozes down, put a clear gel coat polish top coat on it, let it dry and installed it.
It wont ROT, RUST, WATERLOG, or react to Any other surface and I dont think you could break it if you had too. Probably more bullet proof than plate steel, if you do it right you can slap a higher HP outboard on it,,,, And the green reflective coating from the interstate signs looks pretty cool at night reflecting with just a small light back in that area.. REDNECK MOOD LIGHTING!! Helps when your backing up and your playing Demo Derby Night on the lake!!
Believe it or not It was almost $60 cheaper than buying marine grade waterproof plywood, and replacement aluminum plates and I bet itll outlast ANY marine grade plywood.
And it had 12 bolts going thru the motor mount and to the transom mount block., and the transom was held to the bottom of the pontoon deck with 10 bolts going up thru 5 full length crossmember channels . Motor was a 115hp Mercury inline 6. Pontoon boat was 28foot or 26 foot, 2 round aluminum toons. Last year he bolted a 140hp merc on it and the transom and the rear structure has NO problem with the weight or the HP.
