Dumb question I suppose. This is my first alpha one genII - on a 1996 4.3LX. My previous boat had an old 2 stroke outboard and I was used to all the water and exhaust going through the prop. Can someone explain the normal path for water and exhaust on an Alpha One Gen 2 stern drive- circa 1995? I was running on the muffs and I saw water pouring out of the transom. I shut down and raised the stern drive up- and I saw there were two 3/4" or so diameter holes, one on each corner/side of the transom. I'm assuming the water was coming out of those holes and it was supposed to, but I wanted to make sure. I have no leaks on the inside of the boat. I was nervous because I assumed that all the cooling water is supposed to come out thru the prop.
