Re: Transom repair advice needed
I replaced the stringers last year, didnt glass them to the transom, glass o phobia, just butted them up to the transom and glued... It's lucky I didn't hit anything with the LU. Right now, with the transom out, the stringer ends are floating in the air. I was going to make doublers(2 per each of 2 stringers) and extend the stringer aft and notch the transom. This weekend I proceded without notching the transom, details follow for the record. I cut and fit one 3/4 ply transom board to fit the cavity, then cut another from that pattern and put them both in the cavity then screwed the 2 plys together then trimmed so that I got about 1/4 inch play top to bottom and side to side of the wood transom inside the cavity. I was surprized to find that the best fit did not result in flush edges for the 2 plys. The aft ply rode approx 1/2 higher than the inside ply, a good thing because the the epoxy will form a lip on the bottom and better hold the transom in. Then I epoxied the plys together using the screw holes as locaters, then covered the entire transom wood with fiberglass cloth and epoxy resin so as to maybe avoid cracking of the epoxy somewhere down the road.The transom wood is now entirely encased. Next,with the transom still out and after checking that it fits in the cavity, I will epoxy the old fiberglass skin back on since I can lay it flat and press it on the garage floor with weights to get a good flat bond. Then comes epoxying the whole transom into the cavity. <br /><br />Considering both replys Hooty and Oldboat1, I will cap each stringer with 2 or 3 layers of 3/4" plywood disks made up like a layer cake with notches for the stringer, epoxy the disks flush to the inside of the transom, capturing each stringer, then glass it all in. Thanks for the ideas!<br /><br />I described how I did the stringers in another post, but I would do it differently today now that I have successfully covered the transom and seen how easy it is to do. I would completely encase each stringer in fiberglass cloth w epoxy resin prior to attaching it to the hull.
